[GRASS-dev] [GRASS GIS] #1575: r.horizon bugfix and speedup
trac at osgeo.org
Tue Apr 9 01:06:10 PDT 2013
Reporter: sprice | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Raster | Version: svn-trunk
Keywords: r.horizon | Platform: All
Cpu: All |
Comment(by hamish):
C Q: is declaring variables mid-function (say at the start of an if(){}
statement) fully portable to all the platforms/compilers that we wish to
support? how about declaring and initializing variables at the same time?
+/-'s?
does the /100 -> *0.01 remove the expensive divide op, or is it just about
removing the cumulative number of ops?
is declaring a new variable relatively inexpensive vs declaring it then
using it?
which part of the patch specifically is the bug?
(as concerned with readability/maintainability as I am with speed; w/ code
comments where appropriate we can have the best of both worlds; the "Code
folded into the 'if' statement:" explanation is great tx)
thanks,
educational-mode non-comp.sci. major Hamish
ps- in general I think we can gain a huge amount from running various bits
of grass through a profiler. the "Bugs" wiki page has some suggestions,
the yes,still-free-for-non-commercial/research-use Intel C compiler has a
very good profiler+tutorial too. thanks Seth!
Ticket URL: <https://trac.osgeo.org/grass/ticket/1575#comment:4>
