[GRASS-dev] [GRASS GIS] #1832: Python scripts are with mixed tabs and spaces
trac at osgeo.org
Tue Apr 9 05:57:55 PDT 2013
Reporter: klo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Python | Version: unspecified
Keywords: indent | Platform: Unspecified
Cpu: Unspecified |
Comment(by zarch):
Replying to [comment:8 hamish]:
> Replying to [ticket:1832 klo]:
> > Mixing tabs and spaces is not good idea:
> > http://www.python.org/dev/peps/pep-0008/#tabs-or-spaces
> annoyingly, it asserts it is so but does not explain why. is it just
that
> lots of people submit code after editing with braindead text editors,
> or is it something inherent in the python language which makes it so...?
The problem is the inconsistency.
Python cleaned the syntax as much as possible, and use the space to define
the code block, using a mixed code can cause troubles [0,1] because you
are not consistent, and it is prone to errors.
Moreover in python3 file with mixed syntax will not work.
Personally I think that we must choose the style to use and add pre-commit
check consistently.
Using tabs to indent make problems when you want to aligned with opening
delimiter, like:
#!python
# Aligned with opening delimiter
foo = long_function_name(var_one, var_two,
var_three, var_four)
With spaces you are sure that the code look the same for all the
developers and not affect external source code viewers (e.g. the likes of
github, pastebin, etc).
Pietro
[0] http://www.jroller.com/larrywilliams/entry/mixing_tabs_and_spaces_in
[1] http://enjoydoingitwrong.wordpress.com/2009/03/24/mixing-tabs-and-
spaces-in-python/
Ticket URL: <http://trac.osgeo.org/grass/ticket/1832#comment:9>
