[GRASS-dev] [GRASS GIS] #1924: r.watershed - empty stream segment map
trac at osgeo.org
Wed Apr 10 01:05:43 PDT 2013
Reporter: jradinger | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Raster | Version: svn-trunk
Keywords: | Platform: Linux
Cpu: x86-32 |
I am running GRASS 7 SVN (Rev55666, last revision of r.watershed) and face
following two problems with r.watershed:
1) When running with treshhold = 2 I don't get any errors (one warning,
see below), a flow direction map is produced correctly but the '''stream-
segments map is empty'''.
This was (and is still if nothing has changed since one week) in GRASS
6.5.
Here the debug output:
r.watershed --overwrite elevation=distance_raster_tmp_27369 at Fidimo_test
threshold=2 drainage=flow_direction_test stream=segments_test
D1/1: Mode: All in RAM
SECTION 1a (of 5): Initiating Memory.
D1/1: G_find_raster2(): name=distance_raster_tmp_27369
mapset=Fidimo_test
mapset=Fidimo_test
mapset=Fidimo_test
mapset=Fidimo_test
mapset=Fidimo_test
mapset=Fidimo_test
mapset=Fidimo_test
mapset=Fidimo_test
D1/1: G_find_raster(): name=MASK mapset=Fidimo_test
SECTION 1b (of 5): Determining Offmap Flow.
SECTION 2: A* Search.
SECTION 3a: Accumulating Surface Flow with MFD.
D1/1: MFD convergence factor set to 5.
D1/1: ns contour: 41.4214
D1/1: ew contour: 41.4214
D1/1: diag contour: 41.4214
SECTION 3b: Adjusting drainage directions.
SECTION 4: Watershed determination.
SECTION 5: Closing Maps.
D1/1: 0 basins created
WARNING: No basins were created. Verify threshold and region settings.
D1/1: Too many subbasins to reasonably check for color
brightness
D1/1: close segments_test compressed
D1/1: G_find_raster2(): name=segments_test
mapset=Fidimo_test
mapset=Fidimo_test
D1/1: close flow_direction_test compressed
D1/1: G_find_raster2(): name=flow_direction_test
mapset=Fidimo_test
mapset=Fidimo_test
(Wed Apr 10 09:55:17 2013) Command finished (0 sec)
What does the warning mean? My region settings:
g.region -p
projection: 1 (UTM)
zone: 13
datum: nad27
ellipsoid: clark66
north: 4928000
south: 4914000
west: 590000
east: 609000
nsres: 100
ewres: 100
rows: 140
cols: 190
cells: 26600
2) When running with treshold = 0 (default), I get following Error:
threshold=0 drainage=flow_direction_test stream=segments_test
ERROR: USAGE for basin delineation:
/usr/local/grass-7.0.svn/etc/r.watershed/ram -4 elevation=elevation_map
threshold=swale_threshold [flow=overland_flow_map]
[drainage=drain_direction_map] [depression=depression_map]
[accumulation=accumulation_map] [basin=watershed_basin_map]
[stream=stream_segment_map]
USAGE for slope length determination:
/usr/local/grass-7.0.svn/etc/r.watershed/ram [-4] elevation=elevation_map
threshold=swale_threshold [drainage=drain_direction_map]
[depression=depression_map] [accumulation=accumulation_map]
[max_slope_length=max_slope_length] [blocking=overland_blocking_map]
[slope_steepness=slope_steepness_map] length_slope=length_slope_map
[disturbed_land=rill_erosion_map] [slope_deposition=slope_deposition value
or map]USAGE for ARMSED FILE creation:
[stream=stream_segment_map] [half_basin=half_basin_map]
ar=ARMSED_file_name
WARNING: Subprocess failed with exit code 1
I am especially interested in a solution of problem 1 to get also a
segment map as output of r.watershed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1924>
