[GRASS-dev] [GRASS GIS] #893: wx command prompt + d.*: add a new layer
GRASS GIS trac at osgeo.org
Fri Apr 12 20:17:31 PDT 2013
 Reporter:  hamish       |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  6.4.1
Component:  wxGUI        |     Version:  svn-releasebranch64
 Keywords:  display      |    Platform:  All
      Cpu:  All          |
Comment(by hamish):
 Yup, most of the relevant ones all seem to be there now.
 Remaining of possible interest are d.text and d.graph(requires an input
 file).
 d.graph is there in trunk, may be more interesting in future if we can add
 support to have it read+plot eps and svg, or write a standalone converter
 to create d.graph command input from eps,svg. (a GSoC idea)
 d.rast.leg is not there in 6.x, not sure if that matters or even works in
 the wxGUI.
 d.histogram is also not in 6.x.
 Low-value + perhaps not of interest for 6.x are: d.frame (wouldn't work
 right?), d.split.frame(as with d.frame, any purpose?), and d.linegraph.
 not in any goutput.py: d.correlate, d.polar
 fyi bug in 6.x goutput.py; "d.shaded" should have been d.shadedmap (fixed
 in svn).
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/893#comment:3>
