[GRASS-dev] [GRASS GIS] #1928: after v.transform v.to.db gives incorrect length
trac at osgeo.org
Sat Apr 13 00:00:45 PDT 2013
Reporter: pertusus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Vector | Version: svn-releasebranch64
Keywords: | Platform: Linux
Cpu: Unspecified |
I import a dxf without georeferenced information, then scale it with
v.transform. After that the line length obtained through v.to.db is wrong.
If I export the line with v.out.ascii and reimport it, the length is
correct.
A tarball to reproduce is attached.
tar xzvf bug_grass.tar.gz
cd bug_grass
./reproduce.sh
The script will show the lengths that are much lower than the correct
length (should be like 3300 for the first line, for instance).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1928>
