[GRASS-dev] [GRASS GIS] #740: v.edit returns incorrect results	on Windows
    trac at osgeo.org
    Sat Apr 13 01:21:11 PDT 2013
 Reporter:  nuessli    |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  major      |   Milestone:  6.4.3
Component:  LibVector  |     Version:  unspecified
 Keywords:  wingrass   |    Platform:  MSWindows XP
      Cpu:  x86-32     |
Changes (by neteler):
  * milestone:  6.4.2 => 6.4.3
Comment:
 Replying to [ticket:740 nuessli]:
 > How to produce the bug:
 > -Import the data attached (v.in.ascii format=standard)
 v.in.ascii --overwrite input=C:\Users\neteler\Downloads\test.grassascii
 output=testascii format=standard
 > -Ask for the IDs having cats=2 in layer 2 (v.edit layer=2 tool=select
 cats=2 type=centroid)
 > =>Should return 3 ids but only 2 are returned...
 v.edit testascii layer=2 tool=select cats=2 type=centroid
 26,29
 Selecting features...
 2 of 29 features selected from vector map <testascii at user1>
 v.edit complete.
 > -Ask for the IDs having cat=3 in layer 1 (v.edit layer=1  tool=select
 cats=3 type=centroid)
 v.edit testascii layer=1 tool=select cats=3 type=centroid
 29,27
 v.edit complete.
 > This has been tested on 3 different computers on Grass 6.3.0, Grass
 6.4RC5 and Grass 6.4svn(unknown revision). All give exactly the same wrong
 result.
 v.build testascii opt=cdump
 ---------- CATEGORY INDEX DUMP: Number of layers: 3
 Layer      0  number of unique cats:       1  number of cats:      19
 number of types: 1
             type |     count
                4 |        19
  category | type | line/area
         0 |    4 |         1
         0 |    4 |         2
         0 |    4 |         3
         0 |    4 |         4
         0 |    4 |         5
         0 |    4 |         6
         0 |    4 |         7
         0 |    4 |         8
         0 |    4 |         9
         0 |    4 |        10
         0 |    4 |        11
         0 |    4 |        12
         0 |    4 |        13
         0 |    4 |        14
         0 |    4 |        15
         0 |    4 |        16
         0 |    4 |        17
         0 |    4 |        18
         0 |    4 |        19
 Layer      1  number of unique cats:       7  number of cats:      26
 number of types: 2
             type |     count
                8 |        13
               64 |        13
         1 |   64 |         5
         1 |   64 |         6
         1 |    8 |        26
         1 |    8 |        25
         1 |    8 |        24
         1 |   64 |         7
         2 |   64 |         4
         2 |   64 |         5
         2 |    8 |        24
         2 |    8 |        23
         3 |    8 |        29
         3 |    8 |        27
         3 |   64 |         8
         3 |   64 |        10
         3 |    8 |        26
         3 |   64 |         7
         4 |    8 |        20
         4 |   64 |         1
         5 |   64 |         9
         5 |    8 |        29
         5 |    8 |        28
         5 |   64 |        10
         6 |    8 |        21
         6 |   64 |         2
         7 |    8 |        22
         7 |   64 |         3
 Layer      2  number of unique cats:       1  number of cats:       6
 number of types: 2
             type |     count
                8 |         3
               64 |         3
         2 |    8 |        26
         2 |    8 |        29
         2 |   64 |         5
         2 |   64 |         7
         2 |   64 |        10
         2 |    8 |        24
 Tested on today's WinGRASS:
 g.version -g
 version=6.4.3svn
 revision=55719
 date=2013
Ticket URL: <http://trac.osgeo.org/grass/ticket/740#comment:6>
