[GRASS-dev] [GRASS GIS] #1891: wingrass: background dosbox from regular wxgui startup
GRASS GIS trac at osgeo.org
Sat Apr 13 05:59:28 PDT 2013
 Reporter:  hamish    |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  major     |   Milestone:  6.4.3
Component:  Default   |     Version:  svn-releasebranch64
 Keywords:  wingrass  |    Platform:  MSWindows 7
      Cpu:  x86-64    |
Comment(by hamish):
 see also the SW_SHOWMINIMIZED vs. SW_SHOWNORMAL in the icon setup in
 mswindows/GRASS-Installer.nsi.tmpl.
 (maybe you can right click properties or edit the .lnk shortcuts to try
 different values?)
 I suspect if error messages do show up in there, the window will close
 before you could read them. ? I'm not sure, would have to try old copies
 of the installer, but I think this extra window is new behavior. ?
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1891#comment:5>
