[GRASS-dev] [GRASS GIS] #1911: v.hull bit broken output on wingrass
GRASS GIS trac at osgeo.org
Sun Apr 14 01:29:28 PDT 2013
 Reporter:  ahaav                     |       Owner:  grass-dev@…
     Type:  defect                    |      Status:  new
 Priority:  normal                    |   Milestone:  7.0.0
Component:  Vector                    |     Version:  svn-trunk
 Keywords:  wingrass, v.hull, vector  |    Platform:  MSWindows 7
      Cpu:  x86-64                    |
Comment(by neteler):
 Tested with North Carolina sample data set, winGRASS standalone r55764:
 v.hull input=precip_30ynormals at PERMANENT output=hull
 v.info -c hull
 # -> no DB connection
 g.remove vect=hull
 # -> no error
Ticket URL: <https://trac.osgeo.org/grass/ticket/1911#comment:1>
