[GRASS-dev] [GRASS GIS] #1428: WinGRASS + how to deliver Microsoft Visual C++ Redistributable Package (vcredist)?
trac at osgeo.org
Sun Apr 14 02:35:36 PDT 2013
(vcredist)?
Reporter: dhastings | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.3
Component: Installation | Version: 6.4.1
Keywords: wingrass | Platform: MSWindows 7
Cpu: x86-64 |
Comment(by hamish):
fwiw here is the "OS exemption" text of the GPL2 which we have to satisfy:
[...] However, as a
special exception, the source code distributed need not include
anything that is normally distributed (in either source or binary
form) with the major components (compiler, kernel, and so on) of the
operating system on which the executable runs, unless that component
itself accompanies the executable.
If distribution of executable or object code is made by offering
access to copy from a designated place, then offering equivalent
access to copy the source code from the same place counts as
distribution of the source code, even though third parties are not
compelled to copy the source along with the object code.
the key words here are '''unless that component itself accompanies the
executable''', which I read as: we clearly can't bundle it in our all-in-
one grass_installer.exe download. After that what ''accompanies'' means is
up to the lawyers to decide, but between the choices of automatically
download & install vs. ask [Yes][No] then do it (or not), I'm more
comfortable with the "user takes action" option, since then it was the
user's decision not ours.
I don't think the second paragraph above is as relevant, but copied here
in case someone else reads it differently.
fun,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1428#comment:43>
