[GRASS-dev] [GRASS GIS] #1381: wxgui: add monitor calibrate option to prefs
GRASS GIS trac at osgeo.org
Sun Apr 14 06:16:21 PDT 2013
 Reporter:  hamish       |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  major        |   Milestone:  6.4.3
Component:  wxGUI        |     Version:  svn-releasebranch64
 Keywords:  map scale    |    Platform:  All
      Cpu:  All          |
Changes (by vincent):
  * milestone:  6.5.0 => 6.4.3
Comment:
 OK for the tooltip
 The notion of display scale is very useful when performing on-the-fly
 snapshots of the display. Would be great if one could precisely trim his
 display settings.
 I understand retrieving monitor size is not straight, and obviously much
 platform-dependant...
 GIMP's method relies on monitor information delivered by xdpyinfo (am I
 wrong ?), but sometimes this info is not reliable.
 Could the first-aid solution be an option in the Display preferences menu
 (2 input datafields) that allows user to set manually his vertical- &
 horizontal resolutions ? after all, we can believe the user who cares for
 this parameter is aware of how to calculate his proper values, no ?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1381#comment:2>
