[GRASS-dev] [GRASS GIS] #1849: Cannot create a new GRASS Location using a custom proj4 string
trac at osgeo.org
Sun Apr 14 22:16:11 PDT 2013
Reporter: voncasec | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: Projections/Datums | Version: unspecified
Keywords: proj4, location wizard, wxgui | Platform: Linux
Cpu: x86-64 |
Changes (by hamish):
* cc: pkelly (added)
* keywords: proj,proj.4,proj4,location wizard,wxgui => proj4, location
wizard, wxgui
* priority: normal => critical
Comment:
Hi, testing with the latest relbr64 and devbr6,
in the wxPy loc'n wizard, defining by proj4 terms, using the string:
+proj=utm +zone=10 +datum=nad83
it asks me to select from transform options 0-6, then when I press Ok to
that, I get a slightly different error printed in the terminal:
File "/home/hbowman/dev/grass/svn/relbr_6_4/dist.x86_64-unknown-linux-
gnu/
etc/wxpython/location_wizard/wizard.py", line 1517, in OnPageChanging
if len(dtrans) == 0:
TypeError: object of type 'int' has no len()
the error that it's checking for is 'Datum transform is required.', -- but
I don't think it's true, grass is happy enough to let you leave the datum
transform undefined in the PROJ_INFO file. (then it gives you a message
about it, "default transform will be used")
If I change the +datum= to wgs84 I get the same "`Error: No output format
specified, define one of flags -p,-g,-j or -w`" error box pops up. (that
message is from g.proj)
from the grass6 command line, this shows the 0-6 transform list:
g.proj proj4='+proj=utm +zone=10 +datum=nad83' datumtrans=-1
but this shows the 'please use a flag' error message:
g.proj proj4='+proj=utm +zone=10 +datum=wgs84' datumtrans=-1
Adding the g.proj '-t' flag to "Force override of datum transformation
information in input co-ordinate system" makes it print the transform opts
correctly (then exit) for both. I assume the wgs84 continues on as it only
has the 1 case to choose from, so it gets back to main() and then wonders
what to do next since no flags were given.
So a quick fix is to add -t, but why is that needed?
The problem seems to have come in with r53453; adding '-jf' flags is not
the correct thing, that just makes it fail differently.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1849#comment:2>
