[GRASS-dev] [GRASS GIS] #1428: WinGRASS + how to deliver Microsoft Visual C++ Redistributable Package (vcredist)?
trac at osgeo.org
Mon Apr 15 16:43:18 PDT 2013
(vcredist)?
Reporter: dhastings | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.3
Component: Installation | Version: 6.4.3 RCs
Keywords: wingrass | Platform: MSWindows 7
Cpu: x86-64 |
Comment(by hamish):
Replying to [comment:45 hellik]:
> Replying to [comment:42 hamish]:
> > I think it just needs an extra [Yes,please][No,thanks] page at the end
of
> > the installer wizard with a download option like we already have for
the
> > sample datasets.
> are you sure? - regarding the mechanism behind the scene....
I just mean the technique using wget/curl or whatever it is behind the
scenes to download from a URL, uncompress, and install it. (with nice
checks if there is no network connection or the download fails for some
other reason) Bonus would be md5sum checks on the downloaded file(s).
It seems taken care of by NSISdl::download and untgz::extract in your
patch, thanks.
> done by r55817
wording tweaked a little bit in r55819 to use the magic "system" library
language.
The idea to put the d/l in its own page at the end of the installer wizard
instead of with the sample dataset downloads was because I worry it might
get clicked past by someone hitting Next Next Next Next and not paying
attention, then they wonder why it doesn't work.
Another idea to avoid the registry key search- after figuring out which
dlls are actually needed, we'd to compile a tiny program depending on them
and have it run as part of the startup script and fail with a more
informative error message (or, if we can't do much about the "this process
ended" message, we can at least catch that it failed and the startup
script continuing on from there sees the process return code and aborts
with a more informative error message.) ?
Our next step seems to be some quality time spent exploring with
Dependency Walker..
thanks for the patch!
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1428#comment:48>
