[GRASS-dev] [GRASS GIS] #1891: wingrass: background dosbox from regular wxgui startup
GRASS GIS trac at osgeo.org
Tue Apr 16 03:12:24 PDT 2013
 Reporter:  hamish    |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  major     |   Milestone:  6.4.3
Component:  Default   |     Version:  svn-releasebranch64
 Keywords:  wingrass  |    Platform:  MSWindows 7
      Cpu:  x86-64    |
Comment(by hamish):
 see also #1103, this one is a semi-duplicate ticket.
 after a little hunting, I notice the tooltip for the start wxGUI is
 "Launch GRASS ${VERSION_NUMBER} with wxGUI and CMD console", but since
 then the CMD console was switched off in favor of GUI-only mode, so the
 comment is a little out of date. maybe the empty window is more hangover
 effect?
 You can right click on the grass65svn.bat shortcut and go to Properties ->
 Shortcut Tab -> Run: and change to "Minimized", but I wonder why
 SW_SHOWMINIMIZED from the CreateShortCut in GRASS-Installer.nsi.tmpl is
 not always respected? Maybe if you click on the taskbar button for it it
 remembers the last-used state instead of the installer's original state?
 ... is there a way in windows to run a .bat file without opening a dos
 box?
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1891#comment:10>
