[GRASS-dev] [GRASS GIS] #1311: DebCheck QA: Array index is out of bounds
GRASS GIS trac at osgeo.org
Tue Apr 16 19:42:21 PDT 2013
 Reporter:  hamish            |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  normal            |   Milestone:  6.4.3
Component:  Compiling         |     Version:  6.4.0
 Keywords:  r.flow, v.in.dwg  |    Platform:  Linux
      Cpu:  Unspecified       |
Changes (by hamish):
  * milestone:  6.4.2 => 6.4.3
Comment:
 v.in.dwg patch backported to relbr64 in r52908. (done)
 wrt r.flow, the offending code allowing array index of -1 is:
 mem.h:
 #define get(l, row, col) \
     (parm.seg ? \
         (segment_get(l.seg, &v, row + l.row_offset, col + l.col_offset) <
 1 ? \
           (sprintf(string,"r.flow: cannot read segment file for
 %s",l.name),\
            G_fatal_error(string)) : \
          v) : \
         l.buf[row][col])
 #define put(l, row, col, w) \
     (parm.seg ? \
         (v = w, \
          segment_put(l.seg, &v, row + l.row_offset, col + l.col_offset) <
 1 ? \
           (sprintf(string,"r.flow: cannot write segment file for
 %s",l.name), \
          0) : \
         (l.buf[row][col] = w))
 precomp.c:
 static void interpolate_border(void)
     int i, r = region.rows, c = region.cols;
     for (i = 0; i < c; i++) {
         put(el, -1, i, get(el, 0, i) * 2 - get(el, 1, i));
         put(el, r, i, get(el, r - 1, i) * 2 - get(el, r - 2, i));
     for (i = 0; i < r; i++) {
         put(el, i, -1, get(el, i, 0) * 2 - get(el, i, 1));
         put(el, i, c, get(el, i, c - 1) * 2 - get(el, i, c - 2));
     put(el, -1, -1, 3 * get(el, 0, 0) - get(el, 0, 1) - get(el, 1, 0));
     put(el, -1, c,
         3 * get(el, 0, c - 1) - get(el, 0, c - 2) - get(el, 1, c - 1));
     put(el, r, -1,
         3 * get(el, r - 1, 0) - get(el, r - 2, 0) - get(el, r - 1, 1));
     put(el, r, c,
         3 * get(el, r - 1, c - 1) - get(el, r - 2, c - 1) - get(el, r - 1,
        c - 2));
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1311#comment:5>
