[GRASS-dev] [GRASS-user] Using r.quantile result with r.recode
Pedro Venâncio
pedrongvenancio at yahoo.com
Wed Apr 17 01:33:28 PDT 2013
Hi Glynn,
> ----- Original Message -----
> From: Glynn Clements
> r.recode will treat boundary values as belonging to the upper range,
> e.g. in the above example, 6.0 will get recoded to 2.
So we can not use directly the result of r.quantile with -r flag in r.recode, right?
In the example, 6 should be recoded to 1, right?
Thank you very much!
Best regards,
Pedro
Pedro Venâncio wrote:
> Thank you very much for your answer!
> My question lies precisely in the need to know if a quantile value
> which falls as the upper limit for one range and the lower limit of
> the next, should belong to the class anterior or posterior.
> For example, assuming that r.quantile (with -r flag) gives this result:
> 2:6:1
> 6:8:2
> 8:12:3
> 12:20:4
> 20:873:5
> the value 6 should belong to the first class or second?
This behaviour stems from Rast_fpreclass_get_cell_value() in
lib/raster/fpreclass.c, and isn't configurable (i.e. there's no way
that r.recode's behaviour could be modified without modifying the
fpreclass functions).
Glynn Clements <glynn gclements.plus.com>
