[GRASS-dev] [GRASS GIS] #1068: unnecessary error information at GRASS startup
GRASS GIS trac at osgeo.org
Wed Apr 17 02:22:04 PDT 2013
 Reporter:  msieczka  |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  minor     |   Milestone:  6.4.0
Component:  Startup   |     Version:  svn-releasebranch64
 Keywords:            |    Platform:  All
      Cpu:  All       |
Changes (by hamish):
  * component:  Default => Startup
Comment:
 If the last-known mapset or location isn't found any more, an error saying
 it isn't found seems entirely appropriate. The expected behaviour (load up
 the last mapset) is not possible, and any time that the expected thing
 isn't going to happen there should be warning bells sounding.
 The thing to worry about, I think, is how well it recovers from that
 situation..
 the current 6.x wxGUI gives this in the terminal if the mapset went away:
 ERROR: MAPSET user1 not found
 ERROR: Mapset <user1> not found
 but loads up the loc'n with the list of existing mapsets.
 If the loc'n is no longer there the wxGUI startup gives you:
 Cleaning up temporary files ...
 Starting GRASS ...
 access: No such file or directory
 ERROR: LOCATION << /path/to/old/name >> not available
 then loads up the GISDBASE dir and selects the first loc'n there.
 The -text version gives this after esc-enter, then asks if you want to
 create it.
 Mapset <<user1>> is not available
 For an invalid loc'n it is similar: asks if you wish to create a new loc'n
 by that name.
 it all seems ok to me.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1068#comment:3>
