[GRASS-dev] [GRASS GIS] #640: setup.py may use different Python than configured for GRASS
trac at osgeo.org
Wed Apr 17 07:30:50 PDT 2013
Reporter: kyngchaos | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.5.0
Component: Compiling | Version: 6.4.0 RCs
Keywords: python | Platform: Unspecified
Cpu: Unspecified |
Comment(by kyngchaos):
Ah, right.
Looks like in python.make it's just a compile command. Not an issue for
the OS X 32bit vs. 64bit problem, but important to compile for the right
version of python.
I also found $(PYTHON) in the wx gui makefile. There it's just running
python scripts to generate some files, doesn't look to me like the python
version is important.
Configuring a PYTHON could also be useful if some wx stuff is run at
compile time, to get around the 32bit OS X problem with old wxpython
versions, and on OS X wxpython python scripts need to run in pythonw...
hmm, there might already be some of those - wx-based modules that are run
to generate the help files.
Ticket URL: <https://trac.osgeo.org/grass/ticket/640#comment:7>
