[GRASS-dev] [GRASS GIS] #1935: v.out.ogr removed export directory when dsn= is incorrectly specified.
trac at osgeo.org
Wed Apr 17 15:07:50 PDT 2013
Reporter: cgsbob | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Keywords: | Platform: Linux
Cpu: Unspecified |
I can't believe I specified a dsn without escaping the space character.
So, when I saw the error below, I figured that the dsn caused this
problem. So, I tested my theory by setting the dsn to /tmp/hydro.shp
without any errors. When I went to see if any files were written in
"/media/STORE N GO/Sac", I discovered that this directory was gone!
(Wed Apr 17 11:36:43 2013)
v.out.ogr -c -e --verbose input=sac_course at Data dsn=/media/STORE N
GO/Sac/hydro.shp format=ESRI_Shapefile
Exporting 118696 features...
ERROR 1: Error in psSHP->sHooks.Fwrite() while writing
object to .shp file.
ERROR 1: Failure writing DBF record 1555.
'''I hit CTRL-C'''
Please note that the data are left in inconsistent state and may be
corrupted
(Wed Apr 17 11:37:41 2013) Command aborted (57 sec)
Export vector to /tmp works fine
(Wed Apr 17 11:38:05 2013)
v.out.ogr -c -e --verbose input=sac_course at Data dsn=/tmp/hydro.shp
v.out.ogr complete. 118696 features written to <sac_course>
(ESRI_Shapefile).
(Wed Apr 17 11:39:05 2013) Command finished (59 sec)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1935>
