[GRASS-dev] [GRASS GIS] #1727: v.in.lines not work on Window 7 64 bit
GRASS GIS trac at osgeo.org
Thu Apr 18 03:39:04 PDT 2013
 Reporter:  antonioall  |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  normal      |   Milestone:  6.4.3
Component:  Vector      |     Version:  svn-trunk
 Keywords:  v.in.lines  |    Platform:  MSWindows 7
      Cpu:  x86-64      |
Comment(by hamish):
 Hi, just testing with the latest wingrass 6.5 nightly build.
 Your example works for me from the MSYS terminal, but not from the cmd.exe
 dos box prompt, as it can't find v.in.mapgen when called from within the
 v.in.lines script -- the old problem of calling scripts from inside of
 scripts is back, at least for the dos box.
 looking at the v.in.mapgen.bat file in $GISBASE/bin/ I see that all the
 auto-gen .bat files there have UNIX line endings in them. (extra char
 shows up in notepad.exe)
 Seems that we need to do more unix2dos calls in the Makefiles to fix those
 (what changed?). In this case it doesn't fix it; also from the dos box
 window also module guis and g.gui fail with "no module named
 grass.script".
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1727#comment:6>
