[GRASS-dev] [GRASS GIS] #1727: v.in.lines not work on Window 7 64 bit
trac at osgeo.org
Thu Apr 18 05:10:41 PDT 2013
Reporter: antonioall | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: Vector | Version: svn-trunk
Keywords: v.in.lines, g.tempfile | Platform: MSWindows 7
Cpu: x86-64 |
Comment(by hamish):
Replying to [comment:8 hamish]:
> the GISDBASE string without `/c/` or `C:\` is coming directly from
g.gisenv's
> GISDBASE setting. (via lib/gis/gisdbase.c's G_gisdbase())
that's it: editing the C:\Docs and Settings\Username\Application
Data\GRASS6\grassrc6 file while GRASS is not running, or just adding "c:"
in the GISDBASE box in the grass startup screen, allows v.in.lines to find
its tempfile and import the file correctly.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1727#comment:9>
