[GRASS-dev] [GRASS GIS] #1933: v.overlay ends with sigsegv in cut lines by polygon
trac at osgeo.org
Thu Apr 18 06:34:39 PDT 2013
Reporter: mapycz | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: blocker | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Resolution: | Keywords: v.overlay
Platform: Linux | Cpu: x86-64
Comment(by mmetz):
Replying to [comment:12 mapycz]:
> we discover that problem appear only if we generate contours from dem ,
than smooth it and than v.overlay .
OK. The contours are 3D, the polygon is 2D, that causes problems for the
clipping.
> Everything work if smoothed contour was saved to shapefile and then read
from it and then clipping
You can also transform contour z values to zero with v.transform zscale=0,
then v.overlay.
You could create a new ticket for the 3D lines clipping problem.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1933#comment:13>
