[GRASS-dev] [GRASS GIS] #1727: v.in.lines not work on Window 7 64 bit
GRASS GIS trac at osgeo.org
Thu Apr 18 17:52:11 PDT 2013
 Reporter:  antonioall              |       Owner:  grass-dev@…
     Type:  defect                  |      Status:  new
 Priority:  critical                |   Milestone:  6.4.3
Component:  Vector                  |     Version:  svn-trunk
 Keywords:  v.in.lines, g.tempfile  |    Platform:  MSWindows 7
      Cpu:  x86-64                  |
Comment(by hamish):
 Attempt at giving the script .bat files DOS line endings committed to
 devbr6 in r55904. hopefully it helps for that part of the problem.
 I'm not sure how GISDBASE was losing its C: part, removing the
 %APPDATA%/GRASS6/grassrc file and starting over it puts it in and
 v.in.lines works...
 the wingrass grassrc6 file is originally created by lib/init/Init.bat, and
 GISDBASE there by `%USERPROFILE%" | g.dirseps -g`, which preserves the
 full thing.
 Maybe the result of some historical left-over, but it happened to both me
 and antonioall ..
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1727#comment:10>
