[GRASS-dev] Pipe Error in v.db.renamecol when renaming a column
SWAPAN GHOSH swap.ghsh at gmail.com
Sat Apr 20 09:17:34 PDT 2013
I call v.db.renamecol from command console. I don't know wheather '|'
involved or not, for that I have to check the shell script for
v.db.renamecol.
The grass version is fresh as 6.5. which is older than 2 months.
Regards,
Swapan
On Apr 20, 2013 2:27 PM, "Markus Neteler" <neteler at osgeo.org> wrote:
> Hi,
> is it a fresh GRASS 6.5.svn/OSGeo4W version? (see g.version or "about
GRASS").
> Is any "|" character involved like here:
> http://trac.osgeo.org/grass/ticket/1633
> And do you called v.db.renamecol from the wxGUI?
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130420/5f82df0c/attachment.html>
