[GRASS-dev] [GRASS GIS] #1940: wingrass - nsis - script in release mode: !define SVN_REVISION "@GRASS_VERSION_SVN@" not set
GRASS GIS trac at osgeo.org
Sun Apr 21 04:57:37 PDT 2013
 Reporter:  hellik     |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  critical   |   Milestone:  6.4.3
Component:  Packaging  |     Version:  6.4.3 RCs
 Keywords:  nsis       |    Platform:  MSWindows 7
      Cpu:  x86-64     |
Comment(by martinl):
 Replying to [comment:2 martinl]:
 > replacement should be done automatically
 (source:grass/branches/releasebranch_6_4/mswindows/Makefile#L22) when SVN
 rev number is defined in
 source:grass/branches/releasebranch_6_4/include/Make/Grass.make.in#L75. Do
 you have `svnversion` in the path (when running `configure`)?
 source code downloaded from SVN? If you use tarball, it will fail (missing
 svn number).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1940#comment:4>
