[GRASS-dev] [GRASS GIS] #1940: wingrass - nsis - script in release mode: !define SVN_REVISION "@GRASS_VERSION_SVN@" not set
GRASS GIS trac at osgeo.org
Sun Apr 21 20:57:13 PDT 2013
 Reporter:  hellik     |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  critical   |   Milestone:  6.4.3
Component:  Packaging  |     Version:  6.4.3 RCs
 Keywords:  nsis       |    Platform:  MSWindows 7
      Cpu:  x86-64     |
Comment(by hamish):
 just to note in the release tarball there are no .svn/ dirs present, so
 svnversion (if installed) should just return "exported" to stdout.
 I'm not sure what happens with 'svn export' of a branch, I assume the
 same, but hellik reports using 'svn checkout', which should have .svn/
 dirs, so something else is going on.
 If there are things which need to be changed just before release, then
 changed back just after, automatically-detecting is best but if that is
 not possible please document what needs to be done in
 src:doc/howto_release.txt.
 fwiw,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1940#comment:7>
