[GRASS-dev] [GRASS GIS] #1939: Add line style option to vareas ps.map
trac at osgeo.org
Sun Apr 21 23:22:20 PDT 2013
Reporter: voncasec | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Ps.map | Version: svn-trunk
Keywords: vareas | Platform: All
Cpu: All |
Changes (by hamish):
* version: svn-releasebranch64 => svn-trunk
* milestone: 6.4.3 => 7.0.0
Comment:
the idea of adding boundary style option to vareas sounds reasonable
enough.
I'm not very much in favor of overridding the vector legend's
representation, better I think to first fix any core problems so that
would never be thought of, instead of adding another work-around for a
program defect.
note that using "color none" is slightly different than "color white" in
your example:
vareas lake
color white
In the case of 'color none' the dashed lines appear on top instead of
below the area fill, and you might consider 'width 0.5' with it.
also fyi a while ago I added some named shortcuts to the vlines 'style'
instruction as the 01 thing is a bit weird to get used to: `solid, dashed,
dotted, dashdotted` words auto-replace into a predefined 01 pattern.
example reformed for the NC sample dataset:
g.region n=248500 s=242000 w=643500 e=649500 res=10
ps.map in=- out=test.ps << EOF
vlines lakes
type boundary
color red
#style 1111110000
style dashed
label Lakes
lpos 1
end
vareas lakes
color none
width 0.5
fcolor blue
label Lakes
lpos 1
end
vlegend
end
end
EOF
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1939#comment:1>
