[GRASS-dev] v.generalize smoothing loop support
Miroslav Talasek miroslav.talasek at seznam.cz
Mon Apr 22 01:40:05 PDT 2013
it this path ok ?
do you use it ?
On 04/17/2013 02:47 PM, Miroslav Talasek wrote:
> is it ok ?
> it add new parameter loop_support which would be 1 or 0 for loop line
> support in
> sliging_averaging algo
> On 04/17/2013 12:46 PM, Markus Metz wrote:
>> On Wed, Apr 17, 2013 at 10:54 AM, Miroslav Talasek
>> <miroslav.talasek at seznam.cz>  wrote:
>>> hi all
>>> i try make contours from DEM ASTER and i was successfull but
>>> contorus is
>>> ugly i try use v.generalze but this function cant change firt and
>>> las point
>>> , but some contrours is like loop (first and last point is the same) so
>>> after smoothing with sliging_averaging algo part around start point
>>> look_ahead wide was unchanged iwas so ugly , so i write patch which
>>> implementing loop line support , check if line is loop (start and
>>> endpoint
>>> is same ) and smooting correctly, is it usabel for others ?
>> Yes, I think this is usuable for others. Do you mind sending the patch?
>> Markus M
>>> black is war contours, blue is orig algo and red is with my patch
>>> MSc. Miroslav Talasek
>>> Developer, Team leader
>>> Seznam.cz, a.s.
>>> Prague
>>> Czech Republic
>>> tel.:+420 234 694 722
>>> fax: +420 234 694 115
>>> gsm: +420 608 934 724
>>> jabber: mirecta at jabber.cz
>>> work-email: miroslav.talasek at firma.seznam.cz
>>> email: miroslav.talasek at seznam.cz
>>> web:http://photo.talasek.sk
>>> grass-dev mailing list
>>> grass-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20130422/2681b5ae/attachment.html>
