[GRASS-dev] [GRASS GIS] #1942: v.label.sa not working with areas
trac at osgeo.org
Mon Apr 22 06:10:02 PDT 2013
Reporter: richardc | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Vector | Version: 6.4.3 RCs
Keywords: | Platform: Linux
Cpu: x86-32 |
Ref: http://osgeo-org.1560.x6.nabble.com/v-label-sa-not-working-with-
areas-td5048543.html
RichardC wrote:
v.label.sa does not work with areas. On running the following I get an
empty labels file.
v.label.sa --verbose map=hydrobasins_africa at hydrolayers type=area
column=MAJ_NAME labels=africa_basins_sa font=Trebuchet_MS size=0.5
color=red
However, it works with lines - I can output a labels file if the layer
comprises line features.
_____________
I just tested with census_wake2000 from the NC demo dataset and can
confirm the issue.
The problem seems to be with the type 'area' which is not recognised
somewhere along the process. Adding the option 'centroid' to the 'type'
parameter and using that option makes it create the expected labels.
I'm not sure which would be the better solution:
- Leave the options as is and change the code so that 'area' is remapped
to 'centroid'
- Change the options from area to centroid.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1942>
