[GRASS-dev] [GRASS GIS] #1942: v.label.sa not working with areas
trac at osgeo.org
Tue Apr 23 03:19:37 PDT 2013
Reporter: richardc | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: Vector | Version: 6.4.3 RCs
Keywords: v.label.sa | Platform: Linux
Cpu: x86-32 |
Comment(by hamish):
the milestone is just an indicator, not policy. it only really needs to be
correct when the ticket is closed, since then it gets auto-added to the
"changes since last version" trac-wiki page. FWIW my logic was that at
this point we should be focusing our energy on the last few major bugs for
6.4.3, the minor stuff can happen later. If someone provides a fix before
then, no problem. As for backporting to relbr64, ''as long as there's time
to test it properly''. Any commit to that branch in the last moments
before release is going to be risky..
shrug, it'll be fixed when it's fixed,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1942#comment:3>
