[GRASS-dev] [GRASS GIS] #1891: wingrass: background dosbox from regular wxgui startup
trac at osgeo.org
Tue Apr 23 15:08:08 PDT 2013
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: Default | Version: svn-releasebranch64
Keywords: wingrass | Platform: MSWindows 7
Cpu: x86-64 |
Comment(by hamish):
I don't think we should consider getting rid the rxvt + msys command line
until the cmd.exe + bash actually works. We can revisit the issue once it
does.
Fixing a couple of things in init.bat yesterday it was apparent that the
:wxpython gui goto target in init.bat is currently written to launch the
wxGUI without a real command window, so an intentional change. I don't say
that is right or wrong, just fyi the way it currently is written.
Hamish
ps- I suggest we create a new sub-menu in the Start->Program Files->GRASS
menu, to contain the lesser used startup methods (command line only,
tcl/tk gui, ...), as it's a bit cluttered right now. I'm not sure where
the MSYS UNIX-only one should go, maybe into another Utilities menu?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1891#comment:26>
