[GRASS-dev] [GRASS GIS] #1727: v.in.lines not work on Window 7 64 bit
GRASS GIS trac at osgeo.org
Tue Apr 23 17:32:41 PDT 2013
  Reporter:  antonioall   |       Owner:  grass-dev@…
      Type:  defect       |      Status:  reopened
  Priority:  critical     |   Milestone:  6.4.3
 Component:  Vector       |     Version:  svn-trunk
Resolution:               |    Keywords:  v.in.lines, g.tempfile
  Platform:  MSWindows 7  |         Cpu:  x86-64
Changes (by hamish):
 * cc: marisn (added)
Comment:
 it's the `GRASS GIS 6.x Old TclTk GUI` startup menu item which is eating
 the C: part of GISDBASE.
 specifically this line in lib/init/gis_set.tcl:
 if { [regexp -- {^GISDBASE.*:(.*)$} $thisline dummy env_database] } {
     set database [string trim $env_database]
 looking into why it isn't like `{|^GISDBASE: \(.*\)$}` already with 'svn
 blame', looks like r45817 introduced it. Maris, do you remember what the
 problem is that was fixing, so we can avoid reintroducing it?
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1727#comment:17>
