[GRASS-dev] [GRASS GIS] #1946: wingrass: demolocation includes .svn/ cruft
GRASS GIS trac at osgeo.org
Wed Apr 24 04:52:09 PDT 2013
 Reporter:  hamish     |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  trivial    |   Milestone:  6.4.3
Component:  Packaging  |     Version:  svn-develbranch6
 Keywords:  wingrass   |    Platform:  MSWindows XP
      Cpu:  x86-32     |
Comment(by hamish):
 so, IIUC, the packager does a 'svn up' on their machine into a local
 C:\osgeo4w dir, then the packaging script recursively copies from within
 that checked out source tree?
 http://trac.osgeo.org/grass/wiki/CompileOnWindows#CreatetheWinGRASSInstaller
 Line 586 of GRASS-Installer.nsi.tmpl has:
 File /r ${DEMOLOCATION_PATH}\*.*
 how to restrict that, or afterwards recursively rm the 6 .svn/ dirs within
 it?
 or just forget anything fancy and remove them by hand after the copy:
 RMDir /r "$GIS_DATABASE\demolocation/.svn"
 RMDir /r "$GIS_DATABASE\demolocation/PERMANENT/.svn"
 RMDir /r "$GIS_DATABASE\demolocation/PERMANENT/vector/.svn"
 RMDir /r "$GIS_DATABASE\demolocation/PERMANENT/vector/mysites/.svn"
 RMDir /r "$GIS_DATABASE\demolocation/PERMANENT/vector/point/.svn"
 RMDir /r "$GIS_DATABASE\demolocation/PERMANENT/dbf/.svn"
 http://nsis.sourceforge.net/Delete_files_and_subdirectories
 (I think that recursive remove is also needed for the extracted ms VC++
 dll dir in Temp/, right now it gets left behind after install)
 thanks,
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1946#comment:8>
