[GRASS-dev] [GRASS GIS] #192: ps.map: geogrid RGB color and ellipsoid
GRASS GIS trac at osgeo.org
Wed Apr 24 06:15:48 PDT 2013
 Reporter:  hamish                           |       Owner:  hamish
     Type:  enhancement                      |      Status:  assigned
 Priority:  normal                           |   Milestone:  6.4.3
Component:  Ps.map                           |     Version:  svn-trunk
 Keywords:  ps.map, geogrid, ellipsoid, RGB  |    Platform:  Unspecified
      Cpu:  Unspecified                      |
Comment(by hamish):
 full RGB support for 'setcolor' backported to relbr64 in r55981. the rest
 which were already backported tested ok.
 still todo before closing this ticket:
 > Also it is unclear to me which ellipsoid geogrid uses. I suspect it is
 the
 > current one, which is fine, but it would be nice to add an option to use
 > WGS84's instead, like "d.grid -w".
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/192#comment:13>
