[GRASS-dev] [GRASS GIS] #1950: wingrass: replace rxvt with cmd.exe
trac at osgeo.org
Wed Apr 24 22:41:06 PDT 2013
Reporter: hamish | Owner: grass-dev@…
Type: task | Status: new
Priority: major | Milestone: 6.4.4
Component: Packaging | Version: svn-develbranch6
Keywords: wingrass | Platform: MSWindows 7
Cpu: All |
Making a new ticket for this as it has little to do with #1891.
the task: replace msys's rxvt.exe with Microsoft's built in conhost.exe
terminal emulator.
IIUC, conhost.exe is new for Windows7, Windows XP doesn't have it. At
least mine doesn't in C:\windows\system32. If so that's a problem, half of
the world's installed Windows systems are still running XP.
know problems with MSys's rxvt:
- not compatible with pdcurses (e.g. r.support run from the command line,
edit categories will fail)
- isatty() function returns false
(I've used it a bunch and not run into any problems, so beyond the above
I'm not really seeing what all the fuss is about. what exactly about it is
buggy?)
the bug where msys converts and C: to /c/ in strings when you don't want
it to -- is that msys's rxvt or something else in their bash.exe?
since msys+rxvt is the most stable of the grass Command Line menu items
right now, I'd strongly suggest to delay replacement of it until 6.4.3 is
out the door.
thanks,
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1950>
