[GRASS-dev] [GRASS GIS] #1891: wingrass: background dosbox from regular wxgui startup
GRASS GIS trac at osgeo.org
Wed Apr 24 22:50:14 PDT 2013
 Reporter:  hamish    |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  major     |   Milestone:  6.4.3
Component:  Default   |     Version:  svn-releasebranch64
 Keywords:  wingrass  |    Platform:  MSWindows 7
      Cpu:  x86-64    |
Comment(by hamish):
 rxvt is nothing to do with this bug beyond that's the only 6.x shell which
 is currently working (mostly) problem free. I've opened #1950 for further
 discussion on replacing it.
 the task in this ticket is to decide if the GUI without a real terminal
 window is what we want as the default, or not, and if so consider to
 replace the grass643.bat file created by the NSIS installer with a new
 grass643.pyw. (the .bat is just a 4 liner which sources env.bat (itself
 just 13 setenv()s) and launches Init.bat, should be easy)
 ... or if we just continue to live with the minimized empty dosbox in the
 taskbar.
 thanks,
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1891#comment:32>
