[GRASS-dev] [GRASS GIS] #1945: wingrass: Command Line can't find grass.python libs
GRASS GIS trac at osgeo.org
Wed Apr 24 23:22:56 PDT 2013
 Reporter:  hamish    |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  6.4.3
Component:  Python    |     Version:  svn-develbranch6
 Keywords:  wingrass  |    Platform:  MSWindows XP
      Cpu:  x86-32    |
Comment(by hamish):
 Replying to [comment:5 glynn]:
 > I don't think so. Unlike bash, Tcl doesn't re-parse the result of
 substitutions.
 ok
 > Also the "... is not recognized as an internal or external command,
 > operable program or batch file." error is generated by Windows in
 response
 > to an attempt to execute a command; it wouldn't be generated by Tcl in
 response
 > to a "source" command.
 > It could be generated by the popen() call in G_gui_tcltk() (although the
 quoting
 > looks okay), or by a Tcl "exec" command.
 I tried on linux with putting a space in $GISBASE, but it worked fine
 there. G_gui_tcltk() has a different #ifdef path for WIN32; I'm not sure
 if the tcltk code does too; I didn't see anything obvious.
 If I "`set GRASS_DEBUG_GUI=true`" to get the different tee+pipe behaviour
 from G_gui_tcltk(), it works and the module gui opens.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1945#comment:6>
