[GRASS-dev] [GRASS GIS] #1950: wingrass: replace rxvt with conhost.exe
GRASS GIS trac at osgeo.org
Thu Apr 25 17:20:34 PDT 2013
 Reporter:  hamish     |       Owner:  grass-dev@…
     Type:  task       |      Status:  new
 Priority:  major      |   Milestone:  6.4.4
Component:  Packaging  |     Version:  svn-develbranch6
 Keywords:  wingrass   |    Platform:  MSWindows 7
      Cpu:  All        |
Comment(by hamish):
 Replying to [comment:7 mmetz]:
 > The only fuss I see is about keeping rxvt.
 I don't care about keeping rxvt. I have no problem with replacing it if
 it's for the best. What I care about is last minute untested [in 6.x]
 changes in the release branch, and keeping the development team a nice
 community to participate in.
 > In rxvt, copy+paste never worked for me,
 I've used it a lot and never had a problem with that, shrug. Just re-
 tested: in rxvt highlight + middle click + external ^V in textpad works
 perfectly for me (both directions), and a /lot/ less annoying than menu,
 mark, menu, cut, then menu, paste in a dosbox. fwiw rxvt font size options
 are nicer too.. ;-)
 > but since I am sometimes trying to fix bugs for wingrass, I changed
 > years ago to system console + sh in my local wingrass versions.
 so you've no experience with the current version and are basing your
 impression on some years old thing?
 > It seems that using rxvt can be regarded as a bug.
 the question is if it is a serious enough problem to risk destabilizing
 the one wingrass command line option in 6.x which is 99% working properly,
 shortly before a public release. !@$!#@$
 > I updated msys.bat to the official stable version (MSYS 2009)
 > in r55996,7 for rebr64, devbr6, respectively.
 thanks for respecting the "just wait a bit" requests of others... great
 collaborative working environment based on mutual respect we have here.
 by the way, you overwrote some local changes to the msys.bat script in
 your commits. (i.e. our "%PART1%" test to see that paths with spaces were
 correctly quoted, see original commit to svn + #905, #629)
 > About changes and testing: this change is not in a release candidate
 > and far from being in an official release. A pity.
 Perhaps, but 6.4.4 doesn't have to be that far away. Shoving core stuff in
 at the last minute is bad bad bad bad, no matter how innocent looking it
 seems. Now we have something else to spend many hours testing, which is
 annoying. --have you started that? was your local replacement+testing done
 for 6.x or trunk?
 I'm partly annoyed as we have a number of other major wingrass bugs to fix
 before release, it's hard to get anyone to work on them, and instead we
 seem to be wasting time and energy here discussing the bike shed.
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1950#comment:8>
