[GRASS-dev] [GRASS GIS] #1946: wingrass: demolocation includes .svn/ cruft
trac at osgeo.org
Thu Apr 25 21:33:50 PDT 2013
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: trivial | Milestone: 6.4.3
Component: Packaging | Version: svn-develbranch6
Keywords: wingrass | Platform: MSWindows XP
Cpu: x86-32 |
Comment(by hamish):
Replying to [comment:12 glynn]:
> Replying to [ticket:1946 hamish]:
> > the nightly build wingrass installers ship '.svn/' files for the
demolocation.
> I think that this isn't restricted to Windows; the "builddemolocation"
> target in the top-level Makefile simply copies the demolocation
directory
> to dist.<arch> (using "tar c ... | tar x ...").
that is correct, it's in all 'make install' for svn builds.
> In 7.x, the demolocation directory has a Makefile which explicitly
> creates target directories and copies files with $(INSTALL_DATA).
since there's no `Other.make` in grass6 I'd just go with the cheap & dirty
approach-of-least-change:
Index: Makefile
--- Makefile (revision 55903)
+++ Makefile (working copy)
@@ -389,6 +389,13 @@
builddemolocation:
test -d ${ARCH_DISTDIR} || ${MAKE_DIR_CMD} ${ARCH_DISTDIR}
-tar cBf - demolocation | (cd ${ARCH_DISTDIR}/ ; tar xBfo - )
2>/dev/null
+ -(cd ${ARCH_DISTDIR}/demolocation ; \
+ rm -rf ".svn" ; \
+ rm -rf "PERMANENT/.svn" ; \
+ rm -rf "PERMANENT/vector/.svn" ; \
+ rm -rf "PERMANENT/vector/mysites/.svn" ; \
+ rm -rf "PERMANENT/vector/point/.svn" ; \
+ rm -rf "PERMANENT/dbf/.svn" )
@ echo "GISDBASE: ${RUN_GISBASE}" > ${RUN_GISRC}
@ echo "LOCATION_NAME: demolocation" >> ${RUN_GISRC}
@ echo "MAPSET: PERMANENT" >> ${RUN_GISRC}
I notice that the last part creates a file called demolocation/.grassrc65,
when it should perhaps be .grassrc6? That's named by Platform.make.in:
RUN_GISRC =
${ARCH_DISTDIR}/demolocation/.grassrc${GRASS_VERSION_MAJOR}${GRASS_VERSION_MINOR}
(RUN_GISRC is used by e.g. Man.make at build time, with the GISRC=
override set to the same variable, so it doesn't matter much what it's
called)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1946#comment:14>
