[GRASS-dev] [GRASS GIS] #1727: v.in.lines not work on Window 7 64 bit
trac at osgeo.org
Thu Apr 25 22:07:59 PDT 2013
Reporter: antonioall | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: critical | Milestone: 6.4.3
Component: Vector | Version: svn-trunk
Resolution: | Keywords: v.in.lines, g.tempfile
Platform: MSWindows 7 | Cpu: x86-64
Comment(by hamish):
re. script-called-from-a-script failure from the 6.x wingrass Command Line
and GIS.m, here's a patch.
Index: lib/init/init.bat
--- lib/init/init.bat (revision 56002)
+++ lib/init/init.bat (working copy)
@@ -24,8 +24,10 @@
set SAVEPATH=%PATH%
rem
-rem DON'T include the scripts/ directory in PATH -- The .bat files in the
-rem bin/ directory are what execute the scripts on Windows.
+rem The .bat files in the \bin directory are what execute the scripts
+rem on Windows. The \scripts dir is added to the PATH automatically by
+rem the wxGUI; for Command Line mode and GIS.m, shell scripts called
from
+rem other shell scripts need to have %GISBASE%\scripts in the PATH.
rem
if exist "%APPDATA%\GRASS6\env.bat" (
@@ -121,9 +123,12 @@
set PYTHONPATH=%PYTHONPATH%;%GISBASE%\etc\python
-if "%GRASS_GUI%"=="text" goto text
if "%GRASS_GUI%"=="wxpython" goto wxpython
+PATH=%PATH%;%GISBASE%\scripts
+if "%GRASS_GUI%"=="text" goto text
+rem Tcl/Tk GUI setup
if not "%GRASS_WISH%"=="" (
"%GRASS_WISH%" "%GISBASE%\etc\gis_set.tcl"
) else (
any comments before committing it?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1727#comment:19>
