[GRASS-dev] [GRASS GIS] #1252: wx location wizard fails to create a winkel tripel location
GRASS GIS trac at osgeo.org
Fri Apr 26 22:23:11 PDT 2013
 Reporter:  hamish                   |       Owner:  grass-dev@…
     Type:  defect                   |      Status:  new
 Priority:  normal                   |   Milestone:  6.4.3
Component:  wxGUI                    |     Version:  svn-develbranch6
 Keywords:  location wizard, wintri  |    Platform:  Linux
      Cpu:  x86-32                   |
Changes (by hamish):
  * keywords:  location wizard => location wizard, wintri
Comment:
 tested with latest 6.4svn. still happens.
  "ERROR: Can't parse PROJ.4-style parameter string"
 adding a debug message to g.proj's input.c (where the above error msg
 comes from), the problematic string it is trying is:
 +proj=wintri +lat_0=0.0 +lat_1=10.0 +lon_0=155 +ellps=wgs84 +a=6378137.000
   +rf=298.257223563 +no_defs +no_defs
 (+no_defs twice?)
 from within a functioning Wintri location created using the text based
 location creator (the daily earthquake map in adhoc), `g.proj -j` gives:
 +proj=wintri
 +lat_0=0.0000000000
 +lat_1=0.0000000000
 +lon_0=155.0000000000
 +a=6378137
 +rf=298.257223563
 +no_defs
 +towgs84=0.000,0.000,0.000
 +to_meter=1.0
 which isn't happy with cs2cs either.
 note +proj=wintri has no inverse projection.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1252#comment:2>
