[GRASS-dev] [GRASS GIS] #1951: Postgres database login problems in db.databases
trac at osgeo.org
Sat Apr 27 07:25:27 PDT 2013
Reporter: davidinosauro | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: svn-trunk
Keywords: | Platform: Linux
Cpu: x86-64 |
Just installed grass7 (freshly compiled) and ran into this problem: with
some modules, grass seems unable to login into the Postgres db, as it
tries to connect as a different user:
`v.db.reconnect.all` gives me a few of theese errors:
DBMI-PostgreSQL driver error:
Connection failed.
FATAL: role "davide" does not exist
ERROR: Unable to create database <host=localhost,dbname=test,port=5432> by
driver <pg>
Where "davide" is actually my username, while I previously ran
`db.login user=postgres password=***`
in fact, most modules correctly connect to db (I can run `v.in.ogr` and
import a shapefile, which will properly create a table on db)
However, the following modules (at least) fail with that error:
* `v.db.reconnect.all -cd`
* `db.databases` (which I found was called by v.db.reconnect.all)
* `grass.pygrass.vector.VectorTopo.open` called from the python shell
I did't dig deep into the problem, but I guess the wrong username could be
the result of calling the db client without explicitly specifying the
username.
Cheers
Davide Kirchner
Ticket URL: <http://trac.osgeo.org/grass/ticket/1951>
