[GRASS-dev] [GRASS GIS] #1554: wxGUI Cartographic Composer: preview broken on Windows
trac at osgeo.org
Sat Apr 27 19:58:57 PDT 2013
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: wxGUI | Version: unspecified
Keywords: cartographic composer, psmap, wingrass | Platform: MSWindows XP
Cpu: Unspecified |
Comment(by hamish):
Replying to [comment:33 annakrat]:
> Replying to [comment:32 hamish]:
> > just tested in a wingrass nightly build, preview fails with unable to
> > find the ps2pdf program.
> Really preview? It fails when creating pdf file (Export to PDF).
right. at creating the pdf, sorry.
in the preview tab pressing the green '>' button makes a page, but it is
all
white except for the map box frame in the preview window. Saving to
PostScript makes a nice file on the disk, all's correct there, just the
preview image is missing.
pressing the PDF button comes back with a pop-up window "ps2pdf exited
with return code 1".
> ps2pdf seems to be missing, we could add it there or maybe call gs
directly?
right, no ps2pdf in \extrabin.
On Debian, ps2pdf comes with the ghostscript package, it's just a shell
script which just calls:
ps2pdfwr -dCompatibilityLevel=1.4
And `ps2pdfwr` is another shell/wrapper script which calls `gs`. It boils
down to:
gs -P- -dSAFER -dCompatibilityLevel=1.4 -q -P- -dNOPAUSE -dBATCH \
-sDEVICE=pdfwrite -sstdout=%stderr -sOutputFile=elevation.pdf \
-P- -dSAFER -dCompatibilityLevel=1.4 -c .setpdfwrite -f \
elevation.ps
just replace elevation.pdf and elevation.ps with %s, and `gs` for
`gswin32c`.
I was a little worried about the %stderr option, but I just tried the
above on the wingrass dosbox command line and it worked! I've a nice pdf
now.
Perhaps hardcode the above long command into an if(wingrass) part of the
composer code, or maybe cleaner to write a little ps2pdf.bat or ps2pdf.pyw
(.pyw to avoid a dosbox popping up; we know python is there..) script to
do it?
minor cosmetics:
* "Generating PostScript..." and "Generating PDF..." never go away after
it's done. Can we clear the status bar after the file is closed?
* I also notice when you add a mapframe with a raster in wingrass the
text in the green rectangle on the draft mode page shows as "MAP
FRAME[]raster: mapname"; the newline in the string is rendered as an
unknown char instead of a newline.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1554#comment:34>
