[GRASS-dev] [GRASS GIS] #1554: wxGUI Cartographic Composer: preview broken on Windows
trac at osgeo.org
Sun Apr 28 05:21:41 PDT 2013
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: wxGUI | Version: unspecified
Keywords: cartographic composer, psmap, wingrass | Platform: MSWindows XP
Cpu: Unspecified |
Comment(by annakrat):
Replying to [comment:34 hamish]:
> minor cosmetics:
> * "Generating PostScript..." and "Generating PDF..." never go away
after it's done. Can we clear the status bar after the file is closed?
I added statusbar messages after exporting PS and PDF files.
> * I also notice when you add a mapframe with a raster in wingrass the
text in the green rectangle on the draft mode page shows as "MAP
FRAME[]raster: mapname"; the newline in the string is rendered as an
unknown char instead of a newline.
this should be fixed already (see comment:22)
Ticket URL: <https://trac.osgeo.org/grass/ticket/1554#comment:39>
