[GRASS-dev] [GRASS GIS] #966: wx attribute table manger fails on wingrass with >188 dbf tables
GRASS GIS trac at osgeo.org
Sun Apr 28 21:02:48 PDT 2013
 Reporter:  hamish    |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  normal    |   Milestone:  6.4.2
Component:  wxGUI     |     Version:  svn-releasebranch64
 Keywords:  wingrass  |    Platform:  MSWindows XP
      Cpu:  x86-32    |
Comment(by hamish):
 retested with the latest 6.5svn nightly snapshot and whatever the heck the
 trouble was here seems to be fixed now.
 In testing notice a couple other little bugletts.
  - even though the column is double precision the attribute manager
 displays the value as single precision %f. Submitting a double precision
 number there gets rounded to single precision.
  - in the cursor query tool on the main map display the vector layer
 doesn't have to be in 'Start editing' mode to change the value of what's
 selected, or a tick box in the query result window which comes up. Raw
 data is sacred and should be read-only unless the user specifically asked
 for it not to be. (with d.what.vect you had to use the -e flag to make it
 editable)
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/966#comment:3>
