[GRASS-dev] [GRASS GIS] #2052: r.in.gdal should not by default call first three bands red, green, blue
trac at osgeo.org
Thu Aug 1 03:21:32 PDT 2013
Reporter: mlennert | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Raster | Version: svn-trunk
Keywords: r.in.gdal, rgb | Platform: Unspecified
Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:4 mlennert]:
> Replying to [comment:2 hamish]:
> > I'm not 100% sure, but ISTR that it was libgdal doing that, r.in.gdal
was just passing the band name along untouched. --> gdal band name
detection bug?
> Yes and no: GDAL does return a !ColorInterp info which is "wrong", but
this is apparently due to the original data:
[https://trac.osgeo.org/gdal/ticket/5177]
> The problem in r.in.gdal is here:
[https://trac.osgeo.org/grass/browser/grass/trunk/raster/r.in.gdal/main.c#L525].
That means the -k flag should be removed and the band number always used
as suffix, or optionally the meaning of the -k flag should be reverted
such that color names are appended only on request?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2052#comment:5>
