[GRASS-dev] Object-based classification [was: Re: i.segment: invalid region id 0]
Moritz Lennert
mlennert at club.worldonline.be
Thu Aug 1 04:40:34 PDT 2013
Pietro,
On 31/07/13 10:01, Pietro wrote:
> I'm working to develop a module that use several machine learning
> technique to classify the segments results...
> the part concerning the hierarchical segmentation is working quite well...
Out of curiosity: which variables are you planning on using for this
classification ?
FYI, here's a list of variables that colleagues established here as
being the ones they use most in objet-based classification:
- mean band values
- brightness (combination of several band values)
- standard deviation of a certain band within an object
- length/width ratio of an object
- GLCM Homogeneity (Haralick)
All of these are implemented in GRASS, except for the length/width ratio.
And of the Haralick indicator, r.texture is pixel-based, evaluating
texture in a given neighborhood. Don't know how difficult it would be to
add the option to calculate the same indicators within the polygons
defined in a cover map.
Moritz
