[GRASS-dev] GRASS-dev] On i.histo.match (Re: On (Landsat) imagery naming patterns)
Nikos Alexandris
nik at nikosalexandris.net
Thu Aug 1 05:01:20 PDT 2013
Moritz:
> > >>>> r.rescale is just a frontend to r.reclass. and as such is meant for
> > >>>> CELLmaps. It should'nt make a difference whether it is 8-bit or more,
> > >>>> though. For DCELL you can try to use r.recode.
Nikos:
> > >>> Didn't work also (tried the previous days) -- I can try again.
Moritz:
> > >> Please be more precise than "didn't work"...
Nikos:
> > > Right, "be more precise" is the key to "freedom" :D. Indeed, I used to
> > > say (either in a "rules" file, or directly using "...<< EOF"
> > > I altered the rules file like
> > > 0.001:1.0:0:255
> > > This works-out! Now, the recoded image is
> > > r.recode in=Red_ToAR out=Red_ToAR_recoded_255 rules=recode_rules --o
> > > r.stats Red_ToAR_recoded_255
> > > 100%
> > > 5
> > > 6
> > > 7
> > > ....> Many values in-between
> > > 195
> > > 196
> > > 197
> > > And the histogram looks "nice" as well. I didn't grasp that -- from
> > > where
> > > should I? In the manual there is only an example from int to float
> > > (however, indeed, instructing 0.1 as the "target" min value).
Moritz:
> > There does seem to be a bug in r.recode. Your first rule set should work
> > if you set the -d flag. Maybe you can file a ticket ?
Nikos:
> Oh man... I need to rest. The "-d" flag... that's it :-p
On the other hand, even if I would read it (because I did not read carefully
the --help before), it reads:
-d Force output to 'double' raster map type (DCELL)
In this case I have a DCELL Input, recoding in to CELL Output. How is this
related?
N
