[GRASS-dev] standalone installer cleanup
Martin Landa
landa.martin at gmail.com
Fri Aug 2 02:44:13 PDT 2013
2013/8/2 Hamish <hamish_b at yahoo.com>:
> re. r57342, the PROJ_LIB variable is needed by e.g. cs2cs used by some scripts,
are you sure about that?, proj lib in the path (`extralib`) or it
refers to share stuff?
> and I'm not sure if the removal of tcl/tk from the PATH was intentional or just an over-merge, but fwiw a functioning gis.m should remain as an alternative in case there are multiple-python install problems (as ongoing) or just because someone likes to use it for whatever reason.
it's intentional. BTW, tcl/tk is currently only GUI which is working
in standalone installer. wxGUI is broken thanks to MAXREPEAT problem.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
