[GRASS-dev] standalone installer cleanup
Martin Landa landa.martin at gmail.com
Fri Aug 2 06:42:27 PDT 2013
2013/8/2 Martin Landa <landa.martin at gmail.com>:
>> 2013/8/2 Hamish <hamish_b at yahoo.com>:
>>> re. r57342, the PROJ_LIB variable is needed by e.g. cs2cs used by some scripts,
>> are you sure about that?, proj lib in the path (`extralib`) or it
>> refers to share stuff?
> quickly checking proj manual. IAIW, PROJ_LIB should point to the
> `share` directory. If so I will restore this environmental variable.
done in all active branches. Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
