[GRASS-dev] [GRASS GIS] #2042: wxgui: no more menu access to r.in.gdal / v.in.ogr
GRASS GIS trac at osgeo.org
Fri Aug 2 19:38:10 PDT 2013
 Reporter:  mlennert                  |       Owner:  grass-dev@…
     Type:  defect                    |      Status:  new
 Priority:  normal                    |   Milestone:  7.0.0
Component:  wxGUI                     |     Version:  svn-trunk
 Keywords:  r.in.gdal, v.in.ogr, gui  |    Platform:  Unspecified
      Cpu:  Unspecified               |
Comment(by hamish):
 Replying to [comment:4 martinl]:
 > Moreover running `r.in.gdal` from wxGUI command line should also launch
 GUI
 > front-end. The autogenerated dialog should appear only when `--ui`
 switch is used.
 Oh, I understand what you are saying now. And very much disagree -- if a
 user runs 'r.in.gdal' they should get the real r.in.gdal. They are not
 going to type/guess that name by mistake. If the GUI-wizard version is
 presenting itself by that name, then the trouble is there.
 Or do it like 'g.mapsets -s' to launch the extra GUI. (I don't think
 that's a wonderful solution either, but..)
 I'm not excited about the following name, but if it's a wizard perhaps use
 a different name like "g.gui.raster_import" or some other way to start it,
 then let the users of the GUI get used to that name.
 or maybe "g.gui launch=raster_import"
 or "g.gui wizard=raster_import"
 or "g.gui.wizard raster_import" ??
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2042#comment:6>
